HD axle review 4 all (SOLID NON-FREEWHEEL VERSION)
moronic_kaos
225
Connecticut
Bought it, since my old hub was shot anyway and thought it would be a little more pro having something built into the hub rather than clamped over the top of it (pirate/manic mechanic). Kind of regretting my choice a little.
The Bad:
  1. In order to take the wheel on/off, I've got to drain all the gas, flip the bike upside-down, and use a 12" pry bar to spread the frame
  2. The brake doesn't fit in any feasible or imaginary way, unless I were to cut the frame & weld it together much wider than it came
  3. The sprocket is STILL WOBBLY? First I thought it was just bent from me prying on it but I measured it over and over and its perfect. The connection somehow results in the sprocket wobbling! And yea, its all tight.
  4. The sprocket unscrews 1-2 turns every time it gets bump-started, then hits this other nut which doesn't loosen because its threaded the other way. Then, the engine has to tighten it back once started? Can be fixed with a big washer for a spacer but still, it shouldn't come that way.
  5. You have to loosen & tighten both side's nuts at the same time when removing/installing the wheel, because the axle doesn't lock when trying to do only one side at a time. Extremely annoying when trying to get the wheel in the exact perfect place, since it causes the wheel to slip all over the place when tightening.
  6. The freewheel most of these sites sell with it only screws halfway on. It works though...
The Good:
  1. Did exactly what it said it would do, fit 260mm spokes on one side & 258mm spokes on the other. Easy wheel build for a Cranbrook if anyone's wondering. No need to buy different sized spokes.
  2. The bearings seem to work great
  3. The chain is a lot further from rubbing on the tire than the rag-joint setup results in.
  4. It weighs about 3 times as much as my other hub, and when held & inspected by hand it feels like something suitable to motorize. So it lives up to its name, Heavy-Duty axle.
john_the_great
191
California
Well I'm glad that I'm not the only one who had trouble with fitting the hub into the swing arm, 70% of the reason I bought that axle was the brake so I'm gonna get it to work, even if I hafta chop up my frame.
moronic_kaos
225
Connecticut
UPDATE:
The big threads on the axle the sprocket adapter screws onto actually stripped (resulted in the gear on the rear wheel spinning freely). So I had to weld the sprocket's adapter into place. Everything is still functional & I can still change sprockets if I wanted, the only thing I couldn't do would be to replace a broken spoke. I'm now considering this thing temporary until either manic mechanic gets the CB-110's in or I get the balls to experiment with the shift kit & a Nexus 3-speed wheel.
NEAT TIMES
1,964
PENSACOLA, FL
Kaos
I Have The Part Numbers For The Nice "shaft Spacer`s" That Would Work To Stop Your Sprocket Adapter From Screwing Off When Bump Starting.
They Would Take Up The Space Betwen The Sprocket Adapter And The Drum Brake Hub.
If Interested Go To My "cvt Rack Mount" Thread And Scroll Down Till You Find The Part #`s. They Are Perfect For Your Problem. If You Have Trouble Pm Me.
Recently Bought Two Of Those Hubs With The Free Wheel For Pull Start Titans. Will Not Be Using Them For A While. The Left Hand Thread Freewheel Adapters Are A Large Thread Diamiter. I Needed The 1 3/8" Diam Thread, For Different Wheel`s. Ron
