New please help me
Aymen95
6
california
i cant find a beach cruiser motorized in my area for 250 or less so i was wondering since the engine kit cost 160 should and a beach cruiser is like 50 bucks ...is it easy enough for a 16 year old to do himself? i know how to take off a wheel and put on a chain lol im not the greatest mechianic how much would a bike shop guy charge me to install the motor im going to buy onto a beach cruiser im going to buy also is it bad to get a motorized bike used? thanks
rustycase
Gutter Rider
May 26, 2011
2,746
5
Left coast
Oops!
Kinda seems like you got the facts a little bit askew...
You might be able to find someone in dire need of cash to sell for those prices.
Hope u got patience.
IMO, it's most likely you would end up with $400-$600 in a china girl shortly after you get it running... from all new shiny parts just dropped off the boat.
More if you needed to hire assistance for any part of the build.
Good luck!
rc
TexasDav
528
Houston
Maybe someone in your area will help instruct you, it helps to have experience, but you can build one with a little help. Or learn like most of us thru lots of mistakes and tweeking. Good luck , they are so much fun, and you can have pride in building something with your own hands.
bigdaddy55
20
Texas
I got a huffy big daddy delivered for $151 from Kmart. I got my grubbe skyhawk gt5 delivered for $202. From piston bikes.com. It might not be the best bike but it works for me. The motor came with fairly decent instructions so you can take your time and do it yourself. Good luck ask for help and you will get it here.
John
.shft.
rustycase
Gutter Rider
May 26, 2011
2,746
5
Left coast
I was looking at the Huffy Newport which has inline brakes for about that price, maybe a little more??? Coaster brake is just not gonna cut it.
Nice to hear about good instructions!
rc
bigdaddy55
20
Texas
I tried to find a Newport but it was 189 everywhere I looked, plus shipping. The daddy was only 112, but I paid 23 for shipping and 25 in Texas sales tax. I called huffy about Newport parts and it is new and the parts are not in yet!
Al.Fisherman
1,966
5
Calera, Alabama
Bike and engine $250.00 if running is a STEAL. Here is one I built for a friend...parts alone was $300.00 and not a dime of labor. As a slap in my face, he took it home, rode it for a week or two, and sold it for $600.00.
In my opinion a project like a MB, might be a bigger bite you can chew. I'm sure you will need help..Building a MB takes time, not the 2 hours they tell you it takes. My builds take a full day, You can't take the engine out of the box and throw it together. I have a number of inexpensive modification I do to the engine, and I have very minor problems out of them. First build was early 09 and still trouble free. I don't know your abilities, I myself at 16 took a 3 speed transmission out of a Pontiac, and tore it completely down and rebuilt it. Before that I'd get into a lawnmower now and then.
Read through this......
These are the things that I do, I see that others such as the seals (which I've never had one go bad) mentioned. All these mods or replacements are most likely less then $50.00. Choose what works for you, ignore the rest, but here you have them.
1. Unpack engine, familiarize your self with them.
2. Check for any missing parts. Depending who you buy from you maybe out of luck. Two sellers come to mind. Luckyearlybird and BGF.
3. Remove head
4. Mill head (flat glass and 230 (or finer) grit sand paper. Rub gasket surface to insure it is flat. Check the cylinder also. This will ensure that you have a good gasket surface. Eliminates blown head gaskets by a large percentage.
5. Tap cylinder stud holes to insure they are taped to the bottom. Some engines aren’t taped to the bottom. This can be a problem with the studs pulling out..
6. Discard all studs and nuts. Studs the length of the cylinder are hard to find. Fastener supply has metric all thread. There are a number of vendors that have kits, including myself. But replace them.
7. Replace studs with Metric 8.8 (US Grade 5) Replace nuts with locking nuts. 8mm studs are either 1.0 or 1.25 thread, 6mm studs are 1.0 thread. 8mmX1.0 is not common, but I have 1 engine with them. Do this because the Chinese hardware is junk and prone to strip or shear off.
8. Replace spark plug with a NGK or any good brand.
9. Replace spark plug wire and boot (check with lawnmower supply) or rob from old lawnmower. Use wire core lead. The stock is junk and WILL cause problems down the road.
10. Mount the engine properly, no gaps between the bike tubes and engine mounts.
Engine Mounting pictures by Ron-Becker - Photobucket This will also help to keep the studs from snapping off.
11. Torque 8mm to 120 to 175 INCH POUNDS (max for cast aluminum is 204 inch pounds).
12. Torque 6mm to 60-70 INCH POUNDS (max on these are 75 inch pounds).
13. I install cylinder studs with lock tite, and let set overnight. Optional, I do it to all my builds.
14. I coat the head gasket with Copper Kote (I coat each side twice and let dry)
15. May need to bend exhaust pipe for crank or frame clearance. Recommend using heat. There are other methods, but you won’t hear that from me.
16. Remove or cap magneto white wire off. This is used for low watt lights…it won’t work with a light you can see with, believe me.
17. Re solder blue wire on magneto. Factory has had bad connections, (cold solder joints).
18. Wiring. BLACK Coil wire to BLACK CDI wire, BLUE coil wire to BLUE CDI wire.
19. When hooking the kill switch, don’t be concerned with wire colors. Hook one wire to the black wires, and the other wire to the blue wires. (See # 21)
20. Make sure all wires have a good connection (solder best) and use tape or better yet heat shrink.
21. Hook up kill switch wires AFTER you get engine running. This will eliminate a defective switch should you have trouble starting the engine.
22. Try not to drill holes in the bike frame. Weakens the frame, I did one and the frame split in two.
23. Do away with the clutch cable routing; there are a number of options.
Homemade Mods pictures by Ron-Becker - Photobucket
24. On my kit the rag joint had gauge (Metric) 8.8 bolts, If not replace them. I replaced the nuts with lock nuts.
25. I sealed the wires coming from the magneto out of the engine with RTV.
26. Place a “O” ring in the carburetor throat. NAPA has an assortment. Buy them each.
27. Some say replace the axle with a better one. Never had an axle bend on me.
28. Use thin wire (I use Stainless safety wire).and wrap around the idle screw and secure to the carburetor.
Homemade Mods :: Safety wire the idle screw picture by Ron-Becker - Photobucket
29. For coaster brakes…Some say trim the cap, but I don't like it.
Bearing cap mod - YouTube or a file of sorts can be used.
Al.Fisherman
1,966
5
Calera, Alabama
Alf's word is GOLD!
...tell newbie how many you have built!
rc
I don't like coaster brakes...
Scary!
I haven't built all that many (5), and there are member's builds that would put my builds to shame...No bike I own has coaster brakes. I don't like then either. As far as using the stock kit, my minor modifications, you can't beat my builds. I wouldn't let a bike go for less then $400.00 and that is with a used bike.
