motor dies when hot
Jonda500
86
8
8
Canberra, Australia
Hello I hope somebody may be able to help me, my latest motor bicycle is sh*tting me to tears- every time I ride it, after about 15 minutes or so the motor dies like it's run out of fuel. I have tried changing the carby twice, soldered the ignition wires, removed the in-line fuel filter and checked that the petrol flows. I am so sick of having to pedal home every time I use it.
My bike is a 5 speed repco ATB fitted with a jackshaft shift kit. The motor is a (so called)80cc straight plug head unit with a head light power kit added.
Can these motors over heat? Having 5 gears gives me the ability to maintain a high load on the the engine regardless of speed (-something this motor is shy of as it wont pull 5th gear unless I am going down quite a steep hill! I put it down to not being a high compression motor)
Could the light power unit or the standard ignition components be causing my grief? thanks in advance, John
mew905
647
9
Moose Jaw
feel the CDI immediately after it dies. If it's warm, it may be cooking itself enough that resistance is too high to fire, same with if you're running too hot of a plug (though not likely). These CDI's can be known to cause issues.
Otherwise the only thing I would think is the better atomization as it warms up is causing it to run too lean. Does it start right back up when it cools off? Try playing with the choke lever after it dies. Choke on will richen up the mix and cool the engine off faster.
GearNut
5,104
11
San Diego, Kaliforgnia
When electrical components get hot they can develop an open circuit or a short.
Before digging into the ignition components, I recommend doing the following test at night when the spark will be easier to see.
Check for spark while the engine is hot and has failed. Do not use the spark plug that is in the hot engine as removing it while the cylinder head is hot can easily ruin the threads in the head. Carry a spare, known good spark plug for testing purposes.
Do not lay the test spark plug on a painted surface as the paint will act as an insulator.
The spark plug must have good metal to metal contact with the engine.
If there is no spark the first suspect is the spark plug itself. After the engine cools try installing the test plug. Also of high possibility is the factory spark plug boot on the end of the high voltage spark plug wire. The factory boots are well known for poor design and fall apart on their own.
The easiest and most dependable repair for a bad spark plug boot is to use a known good automotive ignition wire.
Here in one of many threads about changing the wire:
http://motorbicycling.com/showthread.php?t=33185
If that fails to fix the problem then it is time to get a multimeter and check the ignition components. Check 2door's post, #4 in this thread:
http://motorbicycling.com/showthread.php?t=27629
Jonda500
86
8
8
Canberra, Australia
err this may seem like a dumb question, but exactly how does one go about checking for spark on these things???- I have no problem checking the spark on my mower as it has a pull start! Maybe tie a plug tightly to the fins with wire before setting out? (-and install a battery powered headlight!!)
I am using a NGK plug (B5ES I think) and the first thing I do when I get home after breaking down is whip it out hoping to find a bit of crap bridging the gap bit it always looks fine- maybe a little dark but clean. (I am still using 25 to 1 mix(full synthetic scooter oil) as I've only run around 2 litres of the 4 litre break in period.)
The spark plug cap had a rubber end bit that immediately melted itself to the sparkplug and emmitted foul smelling smoke the first time I ran the motor so I simply pulled it off and threw it in the bin!
By the time I've pedalled back home it always starts and runs fine!?! It never breaks down if I just putt up and down my street and the place opposite my driveway even if I keep it running for over half an hour.
I guess it would be relatively easy to swap the coil for another equally crap one to see if that's where the problem lies -preferably unsolder the wires and remove the coil from my other bike that doesn't have this problem hmm... I'll keep you posted, John
crassius
4,032
158
USA
I'd first get rid of that 'light power unit' if it runs off the white wire - these have often caused strange problems.
GearNut
5,104
11
In my last post I failed to mention that the spark plug's electrodes should be gapped to approximately 0.025"/ 0.635mm (acceptable variance of + or - 0.001" or 0.0254mm).
The easiest way to check for spark is to remove the spark pug wire from the spark plug.
Connect the spark plug wire to the test spark plug and lay the test spark plug on top of a cylinder head nut. The metal hex part of the spark plug, the area which you put a wrench onto the spark plug to turn it, is the part that needs to make contact with the cylinder head nut. Use a neodymium magnet on the cylinder head nut to hold the spark plug in place of necessary. As your engine will still be hot when doing this, wear gloves to protect your fingers!
Ride the bike like you are trying to start the engine, using pedal power to crank the engine over. Being careful to keep your balance, look down at the spark plug to see if you have spark. As said earlier, this is best done at night to make seeing the spark easier.
Save yourself $ and labor time and test for failures before replacing parts. There is no sense in replacing a good part.
By "light power unit" I thought he meant the second piggyback coil made by wonderfulcreations/ mightywonderful on ebay.
wheelbender6
4,059
221
TX
Check for spark - Remove your spark plug. Connect the spark plug wire to it again. Rest the little tab at the bottom of the plug on the engine head somewhere (to ground it). Crank the engine over. You should see a spark.
I agree with these guys that it is likely the black ignition box, the one the spark plug wire come from. You need to check for spark as soon as possible after the motor quits on you.
KCvale
3,966
57
48
Phoenix,AZ
Were is your CDI in relation to the engine?
If it right by the exhaust pipe that will cause it to get hot.
Keep your CDI as far away from heat as you can.
Also, unless you are in the arctic a 5 plug is way to hot for summer, you need a 7 or so.
Whether this fixes you or not I urge to get an NGK 5944 (BPR7HIX) Iridium spark plug.
I haven't used a stock plug in any 2-stroke I've built for years, they all get the 5944, sick bikes has them here.
http://www.sickbikeparts.com/catalog/product_info.php?products_id=141
The center number on an NGK is it's heat range, in short how much heat it dissipates to the head or keeps in the engine.
The more white you have in contact where the threads are, the more heat is transferred to the cooling fins, and the pink is just providing an air gap to keep heat in.
I would also have to argue that an air cooled motor dissipates much more heat much quicker in a freezing wind opposed to a frigg'n hot one.
Engine Speed and Load
* If the engine is to be operated at high RPM, under a heavy load, or at high temperatures for long periods a colder heat range may be needed.
* Conversely, if the engine is to be operated at low speeds or at low temperatures for long periods, a hotter heat range might be needed to prevent fouling.
The basic rule is go as high a number as you can until you get plug fouling from it not staying hot enough.
Hope that helps.
Jonda500
86
8
8
Canberra, Australia
Thanks for your help everyone! I am in the middle of winter here in Australia so the temperature I'm riding in is between zero and 15 degrees centigrade.
The light unit is indeed the ebay one from wonderful creations.
My motorized malvern star (which I'm getting a new clutch bearing unit for) has always been reliable so I think borrowing the ignition coil from it will be the next thing I'll try - wont cost me anything but time!
GearNut
5,104
11
The wonderfulcreations lighting coil should not affect the ignition system as it is an entirely separate coil that is not connected to the ignition circuit at any point.
Jonda500
86
8
8
Canberra, Australia
So I changed the coil today - didn't solder the wires though, just used the standard flimsy connecters - took it 5 or 6 times round the block and couldn't get it to die- came back cause I was getting too cold! Because it was such a cold day today I'm not ready to call it fixed yet but I think it might be!
Jonda500
86
8
8
Canberra, Australia
Yep - it must have been a bodgey coil/cdi/plug lead unit - the engine wouldn't idle at all the first 4 or 5 times I used it, then mysteriously came good but kept breaking down once hot. Now i've gone over 25 kilometres without breaking down (except for a chain failure!)
mew905
647
9
Moose Jaw
that's great news. Keep on ridin :) My recommendation though, to save your bearings (and thus your motor, and who knows, maybe even yours) life, drop the $80 or so on a Jaguar CDI or Lightning CDI. They have ignition retard at high RPM to reduce cranking pressures and save your bearings. Particularly the conrod bearings.
Jonda500
86
8
8
Canberra, Australia
Update-so I was wrong, it wasn't the cdi/coil unit at all. When it started doing it again (pretending to run out of fuel whenever the (hot) motor is worked too hard) I changed the coil/cdi again for another known good one, made no difference. Then I checked the spark again & again.. - every time I have checked the spark it has worked(although you have to spin it quite fast to achieve sparking). Then I snipped the white wire off under the left cover, rechecked the blue & black wire connections and disconnected the kill switch completely - still no change! I have pulled the fuel hose off the carb many times and checked that the fuel flows freely. It feels quite like a fuel starvation problem although at times even giving it full choke will still see it refusing to fire at all. Changing the carb didn't fix it so by process of elimination I now think it must be the coil in the engine that the blue&black wires go to that is acting up?!
Jonda500
86
8
8
Canberra, Australia
Update: 160 kms on the clock now and it hasn't broken down since I replaced the magneto stator coil over 100 kilometers ago, so I'm thinking most probably that's what was acting up when hot and was the cause of all my continual breakdowns whenever I dared to go too far or too fast!
Slogger
544
nohio
Thanks for the update, glad you got it fixed. The mag coil lives in a hot and vibration filled environment compared to the CDI. It makes sense that it went bad first.
KCvale
3,966
57
48
Phoenix,AZ
The newer 'no white wire' mag's seem to be a better and may even help when it's a weak magnet issue.
Just out of curiosity, when you put the new mag on, did it go on easy or did you have to really fight the magnet to get it bolted in?
Hopefully the latter was true for you as a weak magnet is an actual problem it took me a whole day to find on a brand new build.
For future reference this my electric system test procedure.
My troubleshooting procedure is simple these days.
Disconnect everything.
Ohm the black magneto wire to a head bolt, it should read a dead short.
If not, check the ground tab on the magneto.
Note:
The new skyhawk CDI's have no white wire, ground is the lower connector but it has a wire from it to ground.
Old style mags with a white wire have a tab out of the mag that solders directly to the mag base for ground and they can come loose, just hold it down and re-solder.
Ohm the magneto from the black and blue wire, 320-380 ohms is ideal, an open or dead short means a bad magneto if the wires are connected.
Ohm the CDI in the 10K-20K scale.
Red+ meter probe to CDI black wire.
Black- meter probe to the spark plug cap.
You should get about 6.9K ohms.
If not it could be a bad wire or cap.
Unscrew the plug wire at the cdi, use pliers or even cut it off and dig the junk out if need be and do the same test above again to the cable screw on the CDI.
If that works get a new wire and plug cap, if not you have a bad CDI.
If all of that is good there is only one thing left, the magnet.
That was indeed the problem with this repair on a new build with a 2014 gasbike.net front page engine kit.
When you pull the 4 bolts out of the magneto mount it should slam itself against the magnet, I mean to the point where it is hard to even get your first bolt in.
A weak magnet that lets you move the mag around pretty easily is not strong enough to create a spark which is what this repair had.
Magnet replaced, problem solved and my repair is done.
