chain issue?
mobbin
usa
bike was riding well and all of a sudden the bike stops at every half turn of the wheel. the chain doesnt seem to be stuck at sprocket when turning, has anyone had this issue? im thinking of trying to adjust the clutch under the cover. any comments advice??
80cc 2 stroke
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Yes, DONT ADJUST THE CLUTCH.
If it stops every half turn of the wheel, its the wheel. That would make the engine turn over several times with each full turn, so its not the engine.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
I also agree. Leave the clutch alone, especially the flower nut!
I'm not clear on exactly what your problem is. "the bike stops at every half turn of the wheel" Is this with the engine not running and with the clutch lever pulled in?
If the clutch is not fully disengaging when you squeeze the handlebar lever the problem is more than likely the clutch cable adjustment. Too much slack. It's common for the cable stop to slip on the cable where it attaches to the clutch actuator arm on the engine. New cables can also stretch initially. Try tightening the cable until there is very little to no slack. Not bow string tight, just enough to take any sag out and report back.
You also said the chain doesn't appear to be "stuck on the sprocket". Nevertheless a loose chain can and will bind or 'bunch up' around the engine drive sprocket. Your chain tension should be set to 1/2" to 3/4" of slack. More than that and it can bind and stop the rear wheel from turning.
crassius
4,032
158
USA
a sprocket out of alignment in the up/down direction will have a tight spot in the chain every 180degrees - adjust your tensioner at the tightest spot of the chain run
if this leaves the chain way loose at some points, re-align the sprocket
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Yep, what crassius said. Still, unless your chain is very tight, it shouldn't lock up unless the sprocket is REALLY out of whack.
leo
250
southern wv
grab a ruler and measure the gap between the end of the sprockets teeth and the spokes, it should be the same distance (or very close) all the way around the sprocket.
it sounds like your sprocket is off a little. if so, you just need to tighten the loose sprocket/rag joint bolts.
Allen_Wrench
Resident Mad Scientist
Feb 6, 2010
2,784
26
36
Indianapolis
See if a couple drive-sprocket-bolts on your rear wheel hub might be hitting the brake arm. Or something similar, depending on how you've attached the drive sprocket. Do you have a coaster brake on the rear?
You could be looking at spending some time holding in the clutch and turning the rear wheel and just staring at every single little thing that moves back there.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Excellent insight.
