CDI test - help verify my results
jasonh
1,590
Longmont, CO
Right now I'm actually wondering it basically charges on the + pulse from the magneto, and then the - signal from the magneto is the extra "trigger" pulse. That seems like it could be logical, but I can't seem to find any info on anything similar.
Any ideas on what kind of ignition mowers use?
jasonh
1,590
Longmont, CO
rudyauction509
160
Spokane, WA
How to make this test work: tie spark plug threads to black wire,
Find a 9 or 12 volt AC TO AC adapter (not AC to dc) and a attach blue wire to one side of the plug (yes plug end) and the black wire to the other.
Now use your 9 volt to pulse the output wires of the transformer. If it doesn't work at first reverse the battery.
Reasons
Magneto actually generates between 10 and 100 volts At blue wire, 6 at white wire (9/12 volt transformer raises voltage)
cdi needs negative pulse to fire. ( transformer creates positive and negative spike( I think))
video: http://youtu.be/USfugC8PAzU Note that I used a 12 volt ac to dc adapter in place of a 9 volt battery as my 9 volt was dead.
if you want to have a better tester and some fun at the same time use a second 9/12 volt ac adapter to derive the first one form an outlet, as shown in 2nd video.
2nd video: http://youtu.be/hXKu8XqCQDE
I ran this setup for an hour and had no problems, the cdi was fine, the adapters were slightly warm.
Note driving the cdi directly from a 120 volt outlet might work, but is much more dangerous as the 2 transformers limit the current to about 25 mA, compared to 15 A. (actual current depends on adapters.)
This test has proven many cdis good and a few bad in the past year or so. The voltage at the blue wire es equivalent to running your motor at full speed, so it can miss a dieing cdi sometimes.
