4 stroke Panther build
truckd
2,837
134
palmdale calif
Whats a Schwinn without a couple of sharp fenders (Just another Schwinn LOL!) the light won't take much modification, you might even get a chunk of aluminum and grind the bottom to fit the fender then mount the light on top of that, just a thought
MotorizedEtc.
159
Fremont, CA
Have your tried this type of light before? Its actually a clearance light for a big rig. Ill try the dremel on it first, the chunk of aluminum sounds nice but a lot of work with a dremel.
truckd
2,837
134
palmdale calif
Find yer angle/curve from front to back on the light then find yer angles from side to side, mark everything out with a sharpie on the aluminum with either paper or cardboard template taken from the fender angles/curves, if you have a doner fender cut a piece off and get the angles from that.
MotorizedEtc.
159
Fremont, CA
Thanks for the tips.
My Speedo came in today, thats the good news. Bad news is I don't think it will work with my front drum brake hub. Sooo maybe I can mod it, not sure though.
The speedo is made in the USA and is quite heavy and sturdy. It is a clipper model made by Stewart Warner(made whizzer speedos I think).
MotorizedEtc.
159
Fremont, CA
well I'm back. My poor bike has been unused for a few years now. It has quite the rusty look now. I just bought some copper tubing to replace the fuel lines since the old ones got bent and started leaking. I am going to hunt down a muffler clamp to fit the bearing carrier and seat tube. I hope she will still run lol.
TheOtherChris
47
SE Idaho
Pics! We need current pics.
Master Link
13
Merced, CA
Thanks for the pictures, like the patina, hope she fires up. I also like the muffler clamp bearing carrier support. My build will be very similar to yours, thanks for the build thread.
