the issue is the tools used dont know when to quite. turn the jet only by fingers. the drill bit mounted solid. the jets outer diameter being the tool now turned with fingers only. use some reverse spin half the time it goes straight and fast. takes about 2 minutes to do the small changes jets need. im not sure about the soldered shut ones however. um will have to get back to you on that.
