I won't go into the plethora of screw-ups this rookie builder made on this direct drive 49cc build before he brought it to me to re-build but I am stuck on the last of his screw ups and could use some advice to get this nightmare out of the shop!
I certainly don't know why but can't even see how he managed to put a key between the bell housing of the cent clutch and motor shaft but I can't get to the back off it to pry it loose without risking the motor case and I can't grab it with anything so the cent clutch bell actually freewheels and not fixed to the shaft.
Heat seems like an option but I don't want to risk the motor seals and the key is wedged in there sideways pretty good.
Is trying to drill it out the only option?
I won't go into everything else he did back-ass backwards but it will eventually serve as an example of how to everything wrong trying to improve with no concept of basic mechanical function.
Thanks guys.
Thanks guys.
