Drive chain is hitting rear engine mount
petersawtelles
6
plantsville CT
hello everyone,
I'm building my 1st kit and just finished assembly. I noticed that the lower part of the drive chain
is extremely close to hitting the rear engine mount. Following the sequence in the instructions I mount the engine using the wide frame bracket for a larger tube to the bike which is a Huffy Cranbrook where it sat comfortably on the frame. I just now doing the final check that the drive chain is too close
to the the rear mount. I tried raising the whole engine but then front mount was very far from
the tube. Is raising the engine and shimming the front mount the correct solution?
thanks for yr time & help in advance,
Peter
