My new, and first, 69 cc was verrrry hard to start...down hill, and would start sputtering while I pedalled, and would finally go after 10-30 seconds.
Then, I would run around the neighbourhood, and stall at a stop sign, and then it would be hard as heck to get started again. I swear my heart rate was higher than if I had no engine!
Here's what seemed to fix it for me...I finally followed just about every guru's advice on here and swapped the plug for a NGK B6H-S that I robbed from my Suzuki outboard, lol
I cannot explain why it would make SO much difference, others have said the stock plugs wotrls fine...but when I left the shop, it fired up in about 15 feet and suddenly I had wayyy more power, it was astounding. In addition, I can know idle with the clutch in...before, no matter what I would do with the idle adjust screw, it would stall...and then of course, more pedalling!
Perhaps not everyone will feel the same improvement, but honestly, after stalling and rough running for the past two days with the old plug (and loose head bolts...crack CRACK! like a backfire, I could believe how much they loosened off after ONE 3 mile run, even though I torqued them to 12 ft/lbs)...after swapping the plug, she started in a great cloud of smoke (Unburnt oily gas from previous failed starts)..and runs so much better...I'm back in the mood!
One thing I did NOT try, was simply cleaning the old plug and replacing it...in my experience with 2-stroke outboards, 16:1 seems a very rich and oily mixture. Even 20:1.
It's possible that the plug fouls very easily, and as an engine won't start, the problem compounds as unburnt gas/oil hits the plug end.
However, even when I first started her the other night, it never ran as good as she does tonight with the NGK!
Yay MB'ling gurus!
Yay science!
