Silverbear, I sent the pulley set up today and PM'd the tracking number and charges. Let us know when it arrives. Thanks.
Looking good sb. Are you leaving that collar on the shaft? If so, just wondering why.And more photos...
Curt, that drill guide is the bomb!It felt like Christmas this past week when first a package arrived from Curtis Fox containing the drill and tap guide he made and loaned to me. Then the cupped pulley msrfan made came in the mail followed by yet another little goody for the CVT modification, the split collar. And with warmer weather it is time for some engine and transmission work.
First off I drained the oil from the crankcase and switched the drain plug to the opposite end of the engine. Since it sits at a tilt in the cantilever frame the drain plug needs to be at the lower end of the engine. Now it is. Second, I cleaned up the head where I had drilled and tapped it in order to thread in a compression release valve purchased on ebay and which was designed for a chainsaw motor. I threaded it in tight after dousing the threads with JBWeld and then added more JBWeld to the topside of the head as a sealer. Then the head got tightened down.
Curt's drill guide is very cool. The guide which msrfan gave a link to a few posts back and which is pretty expensive does not come up to Curt's. You can see in the photo that the guide slips over the 3/4" crankshaft and has three different inserts. One is for a pilot drill bit to start the hole. Next insert has been drilled to guide the bit for the bolt hole and the third insert is for the tap to fit inside. There is just no way to misalign drilling and tapping the crankshaft. Even so, I decided to do the operation first on the spare 5 horse Tecumseh engine which is the same model engine as the one going on the bike, although without the tin work and pull start assembly they sure look different. If I ever need to replace the engine with the spare the crank will be tapped and ready. So, both engines are all set for a bolt at the end of the crank. Cool. Before I send the kit back to Curtis I'm going to drill and tap the crankshaft on my 147cc Jacobsen 2 stroke which is for another build, an upgrade actually. Many thanks, Curt... what a great job you did!
Over the weekend I'll post more photos and some commentary regarding the CVT and msrfan's awesome cupped pulley. Things are coming along!
SB
Without the one on the back side of the transmission there is a bit of wobble of the shaft at the bearings. With it there's no wobble. Maybe that's why on the original shaft there was a nut at the front side and directions for a certain amount of footpound pressure. With the cupped pulley there is nothing firm for it to butt up against without the collar there. So it seems to me anyway.Looking good sb. Are you leaving that collar on the shaft? If so, just wondering why.
Thanks, Rick!Hey SB the Picassa photo order may not suit you but you sure ordered the right parts from the right guys! Very impressive to get 3 guys on the same page of a problem & come out with the solution, especially when each are located at a considerable distance from each other...anyway a "special" bike should involve special & talented friends, which you all are. Rick C.
Yeah, you're probably right. I had a similar problem on the 5/8'' keyed shafts of my homemade 2 speed trans. I fixed it by drilling and tapping 5/16'' X 18 holes and inserting button head bolts in each end. Still had to Loctite the threads. Looks like you should be fine with that setup.Without the one on the back side of the transmission there is a bit of wobble of the shaft at the bearings. With it there's no wobble. Maybe that's why on the original shaft there was a nut at the front side and directions for a certain amount of footpound pressure. With the cupped pulley there is nothing firm for it to butt up against without the collar there. So it seems to me anyway.
SB
Good. I'm glad you think it will be okay. It will be something for me to keep an eye on.Yeah, you're probably right. I had a similar problem on the 5/8'' keyed shafts of my homemade 2 speed trans. I fixed it by drilling and tapping 5/16'' X 18 holes and inserting button head bolts in each end. Still had to Loctite the threads. Looks like you should be fine with that setup.
