Just when I thought I had it all worked out.
Still breaking in the engine on 2nd tank of gas at 16:1 mix. so just over 100 miles on the engine. I get on the bike pedal for a bit to get some speed so I don't fall over, let out the clutch and push down on the pedal at the top of the arc. pedal does not move. If I weighed more maybe I could get it to work. It is like the piston is locked up.
Bike has shift kit on it so that makes it a little complicated.
To get it to start I release the clutch and bounce/roll the bike backwards a few times and finally the piston starts going up and down. Initially it is locked tighter than a drum.
Took off the top end inspected the cylinder walls there is no scoring it looks okay to me, but what do I know. Neighbor says maybe I should use Castrol 2T oil instead of the stuff I am using Ace Hardware 2 stroke.
How long would I have to just run the engine to finish a break in, if that is the issue? Would 7 hours with breaks for cool down seem about right?
I think with the kit still in place I could put on a left rear sprocket on and attach it to the drive sprocket for another 100 miles until the engine is broke in I really don't want to do this.
