Do pirate cycle hub adapters work on 32 spoke wheels?
Sufimystic
16
Lincoln, California
Hello, I am in the middle of my first build and have gotten to the rear drivetrain, I have a 32 spoke rim and the stock "sandwich" gear will not line up properly, I can only get 7 of the 9 bolts to line up properly, does anyone know for sure if the pirate cycles hub adapter will work fine with a 32 spoke setup, I know they work fine for a 38 spoke configuration.
Fun build so far as I love customizing everything. Thank you in advance for any help.
Mark
Sufimystic
16
Lincoln, California
Thank you Hoze513, used 4mm bolts and it worked perfectly, but I mounted the sprocket with the indentation towards the spokes and its slightly out of allignment, tomorrow I'm going to re-install it with the indentation towards the outside, I think it will line up just right., now on to the next stage!
Thanks again, you saved me money and time, greatly appreciated.
Regards.....Mark
