Frustrated!!!
freshwater
22
Arrgh!!! I got the bike running fine the other day and now today I can't seem to get it running again! Did everyone else have this much trouble getting the motor started? I checked everything and there is an excess amount of oil coming out of the exhaust pipe plus the silencer wants to keep blowing out. Are there any professionals here in southern California that I can take my bike to get looked at?
deacon
minor bike philosopher
Jan 15, 2008
8,114
9
north carolina
In in NC can't help you with the repairman abut I would give some thought about what is different since the last time I rode the bike. Like is the kill switch connected now. If so pull it again.
That kind of thing. What is a silencer I have never heard of one other than on a pistol. Don't shoot the bike in some states they arrest you for that.
freshwater
22
Yah I disconnected the kill switch again and still would not start. The silencer is the baffle in the exhaust that is connected with two small screws. Wish there was a repairman nearby.
freshwater
22
Day 5 of the frustration. I cannot start the motor. I about to buy a new one and scrap this one or use it for parts. I dont know what else to do.
DasKapitan
122
Birchwood, WI
www.cetaceanmarine.com
Freshwater - Start again from scratch and go over the basics. This is one of the simplest engines on the planet. Don't give up, Learn from it.
Spark, yes or no?
Spark plug condition, wet or dry?
Fuel, ratio ok?, flowing ok?
Vacuum Seal, good intake manifold gaskets, required to draw fuel into the engine.
Idle set screw condition? still pointed, not busted in the orifice? Open at 4 turns.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
Great suggestions capt'n.
Freshwater, have you tried 1/2 to 3/4 choke and full throttle to start the bicycle motor?
freshwater
22
Bad news guys! When I tried to start it this afternoon The thing that holds the chain in place pulled towards the spokes and broke 3 of them. Now I need a new wheel because the coaster brake broke at the same time. The Wheel wobbles now and I was so closing to flying off the bike. I think the problem why the bike did not start because of the spark plug. The center electrode moved up and down which is not suppose to. I am so Pissed Off at the moment I just want to kick the bike! I now need a new wheel, spark plug, and reinstall the sprocket on the wheel to see IF it will even start.
Norman
LORD VADER Moderator
Jan 16, 2008
2,606
7
71
pampa texas
Thats a bummer but don't give up and don't kick the horse for being onery.
Once you get it running it's a hoot to ride.
aulit
8
the best you can get is an on/off switch like on a weedeater handlebar... instead of a simple button you push once.. it may be easy to install, if you got a small solder...
flynchef
19
Wilmington, IL
I hate to say it but having the chain tensioner hit the spokes is owner error. on a new install in is so very important to tighten every nut and bolt every day for at least two weeks even if you only go around the block. as for the not starting it definitly sounds like the motor is flooded(oil coming out exhaust) after replacing the spark plug do not use full choke. what part of the country are you in? elevation has a lot to do with adjusting the carb.
When i first purchased my motor I lived in illinois now i live in Wyoming up by Yellowstone park when i moved here the motor would not run at all after looking on this site and others i figured out how to get it running again. Now im on my 4th year with my DAX 70cc. pm me and maby i can help you more.
