For those that want a reliable and fairly bright LED light for your bike I built a dirt cheap (only $2 dollars for the whole project) custom lighting solution that might be of use to others.
While this cheap LED flashlight is still really bright and works well without any flicker or issues even when the engine is idling, I would still highly recommend using a battery powered high power 1 Watt or 3 watt LED light in addition to this flashlight since this flashlight does not produce enough light to be of worth other than a visual for others to see you from a distance.
Parts list:
1. LED flash light at the dollar store (usually these flashlights have 3 or 9 LEDs. The flashlight takes 3 AAA batteries so the voltage is 4.5 volts and current usage is around 500 milliamps from my testing with a multimeter)
2. 47 OHM 1/2 WATT resistor, easily found at Fry's or even Radio Shack
Instructions:
Saw off 2/3rds of the flashlight and solder a 47 OHM 1/2 Watt resistor to the positive terminal and then solder the white wire to the resistor (connect it in a series). The negative lead from ground goes to the negative terminal of the flash light. Just zip tie or mount the flashlight however you would like and presto, you're done!
Important Note:
The LED flashlight is capable of taking more milliamps than the output of 500 milliamps from the engine which will kill the engine so the resistor IS NEEDED. I have tested it without the resistor and my engine did die after 2-3 seconds after starting so let this be a warning up front should you omit using the resistor, besides if you skip the resistor and still manage to keep your engine running you'll fry your LED light since the output voltage from the white wire is 7.5V and the light can only handle 4.5V.
Parts list:
Instructions:
Important Note:
