Spooky Tooth has an upgraded carburetor that's advertised as a night and day difference in power compared to the stock carbs. I bought it for 25 bucks and I went from 28 mph to over 35 mph. I would say that's a night and day difference.
Oh I hear ya.....Thanks StewartRacing,
A concern of mine of the CNS is that it has an even larger jet size. Most need to reduce fuel compared to air (lean) to eliminate 4 stroking and improve speed and drivability. If I really knew that I could (absolutely) dial in prober mixture, then I'd be interested. The simplicity of the new NT is great, however, I'd be buying into the same design limitations inherant in the NT. Hmmmm. Thanks for your review. The jury is still out.
Yeah, it's the NT that spooky sells. I've tried the clip on all the settings, and it still does it. I put the stock air filter back on it and that helped a little, maybe. I'm going to put the stock intake back on and see what it does. It's not the gearing. It ran fine before, and i'm using stock gearsIs that the NT carb.??? Keep on going on the needle, your going in the right direction.....My motor isn`t level either, but I just bolted on and was perfect.....Needle is on the 2nd from the top.....Two 1/4" holes drilled in the filter housing....I probably could go down one(leaner) on the needle but it is safe and runs sweet.....It might be gearing too,I`m at 10/42t and weigh 185 lbs....
Keep us posted....
