The biggest hurdle is finding the room between the outer edge of the chain and the caliper. If you have a very small sprocket, 28-30T and a 203mm rotor you might make it but anything larger than a 36T sprocket usually doesn't allow for full pad contact with the rotor. A custom rotor mount might work but be ready for some detailed machine work which isn't going to be cheap, to mount the rotor on the pedal chain side.
Good luck.
