1 gallon tank and paint
fakeplay
67
newburyport ma
Hello, I purchased a 1 gallon tank but it looked like cr ap when I got it. So... I repainted it flat black and liked the way it looked. Problem....when I fueled it after 2 days of drying the gas started eating the paint. Was I spose to hard coat it ? I don't have access the the machine shop I used to. What coating do they use on the original stock 2.5 gas tank that came with the kit ? Thanks
P.S. will the smoke alarm go off if I bake the painted tank in my house oven say.....on 150 degrees ?
Kevlarr
1,628
4
Mi
Especially if you've already put gas in it!
Most spray paints have to cure for a few days before they really are dry and will resist gas.
If you have a hobby shop around get some fuel proof flat black paint. If it'll hold up to alcohol and nitro it'll hold up to gas and 2 cycle oil.
BTW, if you have a garage and 220 going to it an old electric stove works great to bake powder coat.
silverbear
The Boy Who Never Grew Up
Jul 9, 2009
8,325
670
northeastern Minnesota
That's interesting regarding the old electric stove. I'm picturing building something larger say out of firebrick... a kind of oven/kiln large enough to fit in a bicycle frame suspended by wire from the four corners of the oven... use the heating element and controls from the original stove. Would that work, do you think? Powder coat sure is nice.
Silverbear
GearNut
5,104
11
San Diego, Kaliforgnia
If you want to bake spray paint in an oven, 150F is fine. Do not go over that by too much though.
I would leave the part in for at least 1/2 hour to 45 minuits. I have done it many times in the past with excellent results. No I did not ust the oven in my kitchen! That really is asking for health problems.
I have never tested a part for gasoline resistance, however I have read that appliance epoxy paint holds up well.
Kevlarr
1,628
4
Mi
If you want to just cure paint on small parts a toaster oven will work. Check yard sales or thrift shops. Everyone seems to have a toaster oven they don't want. lol
lordoflightaz
296
Phoenix, AZ
I didn't bake my tank, guess I need to check out Goodwill for a toaster oven. I did find that Krylon Clear Triple Glaze seems to work. although I spilled some gas on the tank on day after I painted the tank and that caused an issue, since then the glaze appears to be holding up.
I have an old charbroil barbque and I think I might try that as an oven.
GearNut
5,104
11
A barbeque will also work as an oven. Set a cookie sheet on the grill between the burner rocks and the bottom of the part too be cooked. Do not let the part set directly on the cookie sheet though. Suspend the part if possible, using coat hangers or really stiff wire to make a jig. Put the whole thing in the barbeque and cook slowly on low heat, checking often untill well done.
Never, ever use the barbeque for cooking food afterwards, ever!!!
Kevlarr
1,628
4
Mi
Problem with a BBQ is it would be too hard to regulate the heat, A gas grill adds another issue, when propane or natural gas burns it releases moisture which could mess with your finish.
floridaboy
139
6
18
Hudson, FL.
You could sand down the tank and go to wal-mart and get the Krylon spray paint and put three coats of paint letting it dry betwen coats . Set it out in the sun for a day and you will be good to go. I have painted three tanks this way with no problems.
Kevlarr
1,628
4
Mi
I haven't had much luck with Krylon paint. I have use it because it's the only color that matches the trim on my bike but it seems to scratch VERY easily.
toad772
37
canada
or you could use the barbecue after it probably wouldn't hurt ya
lordoflightaz
296
Phoenix, AZ
Ahh that is no fun. Beef Ribs with metalflake would be so cool. I just knew there was some reason I was keeping the Charbroil around besides it history. It's been sitting on the side of my house unused for the last 4 years.
azbill
3,358
5
Fountain Hills, Arizona
here in AZ it's hotter on your back than the heat in your face from the bar-b-q :)
I do most of my outdoor cooking in the cooler 80 degree weather...when is that coming anyway???
