I know im still in the break in stage but ****! I need more than this!
25:1 oil; Tom's referring to your Air:Fuel ratio. To "richen" is to increase the fuel-delivery. This can be done by increasing the carb-jet size or raising the jet-needle. Get into the habit of using the very powerful SEARCH tool at the top of this page. While you're at it, search for "plug chop".Wait, richen? More oil? I was told go less.
And the needle clip position only controls mix at and below 3/4 throttle. Anything above about 3/4 is determined by jet orifice size. The clip position has no effect on wide open throttle (WOT) conditions.Usually the second slot from the top works good for break-in. This is one setting less than full lean. (Needle one slot from fully bottomed in jet.)
Remember, raising the clip LOWERS the needle and leans the mix.
Lowering the clip RAISES the needle and richens the mix.
