Hi All,
Just clearing out a few leftover sprockets that were either prototype sprockets or may have a blemish or two or simply made in error....I will describe each as best as possible (refer to pic "reading" from top to bottom)
NOT shown: Hobbed 32T offset sprocket...Raw aluminum finish..Only for HD 9
hole mount (8 MM bolts). One or 2 small scratches.
1) 34T sprocket for use with Top Hat OR 9 HD Hole mount 8 MM bolts. Has
Large 2.153" center hole. Light machining marks, scratch, and minor scuff
marks.
2) 36T sprocket. Dual mounting pattern (disc hub mount and HD 9 Hole mount
(8 MM bolts). Does NOT have small 9 Hole bolt pattern for 6MM bolt
mount.
3) 36T Sprocket for Top Hat use OR can be used with factory HD 9 Hole
mount (8 MM bolts). Light scuff mark.
4) 38T Hard Coated Sprocket. For use with Top Hat OR Factory HD 9 hole
mount (8 MM bolts). Perfect BUT I mad the wrong size for the customer
so it is sold as an "extra".
5) Basically the same as #4 above BUT the teeth were not machined thin
enough....Some careful grinder time could take care of it BUT obviously
the hard coat on the teeth would be worn off. Perfect sprocket otherwise.
I would re machine BUT it is hard to re set everything accurately so simply
selling it as is....
6) 50T sprocket...I made the wrong size so here it is!....does NOT have disc
hub mount holes.
$25 INCLUDES shipping to the USA....(Price is for each sprocket. If you want more than 1 sprocket I can combine them to save you shipping).
NOTE: To save me time answering questions as to which ones are sold or still available....If you want one please reply on the forum so others can see
who wants what and then PM me how you'd like to pay for it (Payment info can be found on my myspace page at : myspace.com/kingssalesandservice)
Hope this helps....
Andrew
marks.
mount.
hub mount holes.
Hope this helps....
Andrew
