KTM GP50 clone. Any opinions?
Fatandre
150
Poland
Hi Guys.
I have been doing some research on engines for my new build that you can see in the board track section.
I was wondering what are your thoughts about the thats DAX KMT clone motor.
It is 500 dollars, but you will be getting the 9 hp and so on.
Maybe you could recommend something else in that price range?
Theon
1,440
6
FNQ Australia
4 stroke?
or 2 stroke?
9 HP seems to me more than most would need on a motorized bicycle.
A good 4 stroke getting that sort of power, once set up could end up costing more.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
The KTM is a race engine and makes power at high rpm. Your boardtracker will be silly fast but the engine needs to scream to make real power. Is this what you want for a vintage build?
A large four-stroke will run at a lower rpm and be more fun to pose on as well as being easier to maintain than a screaming 10,000 rpm two-stroke.
Just my opinion.
Theon
1,440
6
FNQ Australia
I'd be thinking 4 stroke if you can afford the time and money to get it done right.
All depends on what you want the bike to do.
I find a well built China Girl meets my needs.
The KTM would be ideal for a real race bike, though others here have some really mean 4 strokes, but $$$.
16v4nrbrgr
1,728
North Bay
I've got s KTM50 clone on my Raven chopper and it's a great engine, it just needs to be revved high to make a lot of power, at lower revs it still makes adequate power though.
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
The KTM 50 do not make anything close to 9hp which is why I let them race in the 8hp capped Midrange class.
My guess would be 6 to 7 HP and they are rather peaky which does not make for a good street bike.
Hopefully we will put one on the dyno at the April 12th race.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
You clean one up right with a 21mm carby done right with pipe.. I would think ya can get 9 at sea level pretty easy.
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
Gotta ditch the stock clutch tho... IME with a real Morini it can be wicked. It gives much better sainity lolrotfl With a Tomor clutch one can actually tame the critter.
16v4nrbrgr
1,728
North Bay
If you have it geared right, the stock clutch is fine for a top speed of about 47 mph and can standing start, if you want to overgear it the clutch will slip and make too much heat. I went about 65 mph with the stock clutch but it didn't like repeated standing starts.
BarelyAWake
7,194
21
Maine
I've not ordered from this vendor, nor do I know much about the KTM50 clones in particular - however as they're a viable 50cc motor I'd like to give one a shot and have searched for both reasonable pricing & validated preformance perimeters... while the latter still questionable (KTM not forthcoming & advertisers being advertisers lol) I've found a potential former, with a decent reputation & a willingness to sell single units: http://www.aliexpress.com/store/product/KTM50-AIR-ENGINE/602744_627840002.html
Hope it helps some, I'm up to me eyeballs in "roundtoit" projects so it's unlikely I'll be gettin' one anytime soon :(
Goat Herder
Gutter Rider
Apr 28, 2008
6,237
20
N.M.
23cc wow. Wounder if they all are or it is a miss type? Was under the impression that little motor was 49cc-ish?
sublunacy
90
ontario
they are all 30 pound motors with 2-3 speeds and friction clutch. That is why im doing 19mm carbs and reeds on ht motors. Mine is unique and sure to please. i like the updated gt2a and gt5a for taking reeds and making looong torque and great midrange. my 2 cents
Fatandre
150
Poland
Back to this.
I am not ready to buy a engine and would like to confirm my question.
Should I go for this KTM or tune a HT?
Have you ordered from here?
Its a good deal for me considering shipping and so on.
I have also liked Freds engines and maybe someone could compare those two?
Also I like the Morini one. Which one would you recommend from them?
Wild Bill
478
Camarillo So. Cal.
I have a KTM clone that I race and ride on the street. Mine has a shift kit and I would say they are pretty loud for the street if you run them a single speed since its a centrifugal clutch and they have to slip to get up to speed. But when you use a shift kit you have to set the clutch rpm real low and they will pull away from a stop even just cracking the throttle a little because of the lower gearing in 1st &2nd gears instead of the full throttle screaming all the time. In a race the noise isn't a problem. But the shifting really helps the standing starts.....lol
