Newb in motorized bicycle
vwron65
12
Delaware
Ron here from Delaware..just started building my project bike..it's a huffy cruiser cranbrook from Walmart for $75.00.. not a bad deal. This site did helped me out alot. i will post some pictures as soon as i find out how to post pictures here. i also seen a lot of cranbrook builders here. pino.
Dave31
11,199
47
Aztlán, Arizona
KCvale
3,966
57
48
Phoenix,AZ
You will face some challenges with the Cranbrook, but it can be made to work.
My first build was a Cranny, I learned a lot.
Just keep in mind that a $75 bike will start showing it's quality issues soon is all.
It is certainly a pretty bike to get your feet wet with however, and you will learn a lot from it.
Just some tips...
If you use the Extended Mounting Kit you can give the front tube a little squeeze with channel locks to get the studs buy like this.
That is corded tire sidewall in between the gap, but all that really matters is the stud on the right passes by, that will keep your motor from twisting left.
Another issue will be the spoke mount sprocket.
All I did was just flip the sprocket over and not use the sprocket side rubber.
It lines up and runs for awhile, a few hundred miles anyway.
Welcome and best of luck on your new build, you picked a challenging bike to start with.
If you have questions try the Search here on 'Cranbrook' as you are far from the first ;-}
vwron65
12
Delaware
Well, i finished the bike and i am ready to test this beast tomorrow. I hope everything goes to plan. This bike is my prototype for my new found hobby. Thanks for all the support.
vwron65
12
Delaware
I took it for a run and i know i'm gonna have to adjust the carb. It keeps cutting off when i try to open it up. I also noticed that the carb has this little tube and is it suppose to have fuel dripping out of it?
vwron65
12
Delaware
Well, i am happy with my set up for now. I think an improvement in the near future is a must. I'll just take it little by little.
kipharley
646
Sanford,Maine
Sounds like you have an air leak around the intake.that's could be why it cuts out when you give it some.Tube on the carb?could you explain that better? Kip
HybriDatsun350
NorCal, USA
First of all, you want your carb to be as level as possible. Second, I'm pretty sure that tube is the bowl overflow tube. I haven't worked on these carbs yet as I'm just getting into this, but I'm pretty sure that's what it is. Leveling out the carb will most likely solve your "leak".
techtiger
15
Springfield, MA
I know this is an old post but I have the same carb shown in that picture. My tube does leak a bit. Is this normal? How about when the petcock for the fuel is off? An instruction with pictures on how to adjust this carb specifically would be greatly appreciated if this is necessary.
Dave31
11,199
47
Aztlán, Arizona
Welcome to the forum techtiger, glad you joined us. Here are some links for you..
http://motorbicycling.com/showthread.php?t=30169
http://motorbicycling.com/showthread.php?t=31685
http://motorbicycling.com/showthread.php?t=24797
http://motorbicycling.com/showthread.php?t=32666
http://motorbicycling.com/showthread.php?t=23450
