I think it would be great if other people put their opinions of their whackers or chainsaws in this thread so that we can make it a desitnation thread for people to check out when they are considering a whacker/chainsaw for a friction drive or other bike purpose.
So I managed to snag 7 used adn junky weed whackers for $15 earlier this past week. None of them will fit my needs to use for a bike but I figured I'd report on how the makes work in terms of use for a bike. Each company sticks with a similar design for all their whackers, so learning from these could be useful.
I picked ups the following:
2 Echo
2 Eager Beavers/Mccullough
1 poulan
2 Craftsman
So far I've only taken the larger of the Mcculloghs apart but here's what I can tell so far:
Eager Beaver/ Mcculough III-SL
Great Walbro carb- fantastic. It uses a standard cable for the throttle, so you could use derailleur cable for it, no more mushing together cables to force a fit.
The carb also has a long throw and a sturdy spring. The long throw means more variations in speed.
The clutch is tiny and the drum is thin and crap, won't last for long and won't stand up to a friction drive.
The housing for the drum is aluminum powder coated, very nice, the casing could be easily kept and cut to allow a spindle to poke out.
The connection for the clutch is short- no elongated shaft like on the ryobi and craftsman. But it is workable. I do not know what size nor thread it is.
The width of this whacker is also pretty narrow, much narrower than my ryobi. The gas tank is easily detachable leaving plenty of attachment points.
This brings me to the final thing about the Eager beaver that I like- the pull start is on the rear side. Meaning that no matter the friction drive set up one could keep the pull start. Something that I like very much.
I think that if you can find a Mcculough or Eager Beaver in the 30cc range it would make a fantastic friction drive. The set up is very good, lots of places to drill and connect, the set ups is very very sturdy, most of the case is made of powder coated cast aluminum. Its small and comes with a carb that will be very easy to adapt.
I'll get some pics of this engine tomorrow.
2 Echo
1 poulan
2 Craftsman
