Re: 4G T Belt Transmission Only (78mm peice of junk
hey man, yes there is a downside to welding the bearing. first you are dealing with an incredible peice of chinese engineering.... basically a piece of junk.
(imagine other words). making sense of the bushing:
that oilite bushing supposed to ride between the clutch drum and the engine shaft doesn't. usually. unless you sand it down, oil it a lot and fiddle with it.
if you dont, then there will be no freewhell anywhere in your drive system...
the cc clutch is all you've got for a freewheel, if you weld that one way bearing. but of course you will have to weld it up, cuz it will break and then you wont be riding...
so basically all i'm saying is, there are two jobs instead of one to consider:
1. welding the bearing up,
2. and freeing up that ruddy bushing...
good luck, and ride safe!
