DoLLeRMaN
I did drill the frame for the front mount. If I was to do it over again I think I'd go with a mounting bracket that I made up after this build and used on a Schwinn Point Beach as shown in photo.
I did have to remove the drive gear on the motor and put a washer (3 or 4 mm?) behind it to line the gear up better with the rear sprocket. You may or may not have this same problem with your motor.
