Both mounts are important but…Yep sorry the rear mount to the seat tube, this which was my point is the critical mount to be square and solid.
True. The rear mount is more important for resisting the drive chain loads. I was talking about vibration resistance when referring to the front mount.well we can agree to disagree, i think the rear mount is more critical as thats where the drive is comming from. ...
muffler clamps; sounds like and effective "stop". thanks for all the good advice; i appreciate you takin time to respond.Besides my custom front mount and stock rear mount, i use a MUFFLER STRAP to hold engine against frame and stop from twisting when accelerating.
I used HOSE CLAMPS on frame under my mounts when i first position my motor to hold it in position til i tighten up the mounts and bolts.
Chimney or muffler strap also comes in handy for extra suport.
Which is precisely the way they were intended to be mounted. k.i.p has done everything right. The better the contact area within the concave mounting points, the better off you'll be as far as vibration and fastener life. You can't argue with success.Personally I am running a solid mount with all stock hardware. A detail that I did see as I read through the posts is no comment of how effective the stock mount set up is without added hardware when it is installed exactly as intended. My frame geometry is tweaked to match the two concave mounting surfaces for 90% contact or better.
When the motor is nested into the crotch of the V it keys itself into place before studs even come into play. Any lateral twisting and axial twisting is inhibited by the two concave contact points working with each other. My studs are not so much holding the motor on as they are just keeping the relationship of the mounts in alignment with the frame so that the mounts do their job.
That being said, I did not want to use any media between the mount and the frame that would distort a good contacting fit. This is just my opinion, but I don't have broken studs or trouble with motor position.
