This is what I'm riding these days.
kevyleven007
1,217
8
texas
cycle force tour de france 17.5" prolouge elite 26" mouuntain bike.21 speed.front wheel brushless hub motor.48v16ah lithium battery.watt meter.
paul
5,547
44
48
66
Kalamazoo, MI
is the 48v 16ah one you got lifepo4? lifepo4 is a better battery then the lithium ion battery from what i been reading
paul
5,547
44
48
66
Kalamazoo, MI
thanks kev. added to my favorites to watch as they get new things in, they have some good pricing from what i am seeing
kevyleven007
1,217
8
texas
lfp or lifepo4 will give you up to 2000 charge cycles.but they are heavier.The lithium ion battery I got is lighter and gives better performance for the size and weight and should get about 800 charge cycles.In the world of bicycles "lighter is better" most times.they each have pros and cons.
paul
5,547
44
48
66
Kalamazoo, MI
i am seeing their is a considerable difference in size and weight. still learning all about electric bicycle batteries
kevyleven007
1,217
8
texas
alluminum box with keyswitch is usually a good way to go.lifepo4 or ncm lithium are both a lot better than anything else.Those water bottle shape ones could be used to build an invisible e bike
kevyleven007
1,217
8
texas
now I am going to ride my bike until the battery is completely discharged.I am going to keep a log of watt meter readings.got a little notebook in my saddle bags
paul
5,547
44
48
66
Kalamazoo, MI
i have a water bottle one ordered. it is gonna be for my mountain bike to play in the woods. 36v 8ah. should get 18 to 20 mph which is more then fast enough to play in the woods with
kevyleven007
1,217
8
texas
Thephx1911
11
I am looking to do smarti pie 111 does the water bottle battery Actually fit in water bottle holder? & does it have the same specs as the box battery. Any info would be Appreciated.
Sent from my iPhone using Forum Runner
paul
5,547
44
48
66
Kalamazoo, MI
it has its own mount with a key so you cannot remove the bottle without the key. specs on it are less then the box battery. it is a 36v 8ah battery and the box ones are 36v 12ah and 48v 10ah batteries. it mounts in seconds. good match for a smart pie,
