PLEASE HELP suspect chain/engine seizure....
SAS
16
Australia
umm yeah but it's worked successfully thus far, so I don't see how that would be an issue..excuse my ignorance :(
GearNut
5,104
11
San Diego, Kaliforgnia
The factory spark plug cap is notorious for failing. They are poorly made. The NGK spark plug wire with built in cap that Ibedayank suggested is very high quality.
The engine needs 3 things to run. Have you checked for all of them?
1. - Fuel, supplied by the carburetor at the correct air/ fuel ratio.
2. - Spark, good and strong, timed to occur at the correct moment of flywheel rotation.
3. - Compression, The combustible intake charge needs to be compressed by the piston into the combustion chamber. 100psi is the minimum acceptable. Less than that and the engine will still run, but poorly.
SAS
16
Australia
hrmm...things to look at.
Certainly start with the cable and work from there.
Thanks heaps.
Will be in touch shortly.
Cheers
