Would this work ok?
Powerstroke816
10
Valparaiso
I have had this bike for about a year and I was wondering if I was to install a 28 tooth sprocket would I lose to much Low end and how much faster would it go?
DIANY
127
nampa
i had a 28t on a 20in wheeel.. 49cc.. it was verry weak going uphill.. i had to gun it and max out before i got to the bottom of the hill to get enough momentum to make it to the top.. sometimes i would have to pedal assist...and it was tough to get up to speed.. semed like there wasnt a long enough road anywhere to get up to top speed.. accelerated really slow... i would suguest a 36t with that 26in tire... maybe 34.. but no less than that unless you want to pedal
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
You'd have to do some pedaling to get it moving, or put a lot of wear on the clutch.
I'm not math-smart enough to figure your speed but someone will probably post a rpm/speed calculator that might give you some idea.
What rear sprocket size are you currently using?
Venice Motor Bikes
Mar 20, 2008
7,271
1,810
Los Angeles, CA.
A 28T rear sprocket is way too small, (unless you only weigh 130 lbs).
I weigh 200 lbs & find that a 36T is a little too small for my weight... I usually recommend 40T sprockets for most bikes.
