How do you mount your sprocket ?
How Do you Mount Your Sprocket ?
  • Total voters
    16
cmanns
132
Santa Cruz, California
I just slide the sprocket on with a few screws with these thick curved washers with the flat side on the sprocket, the curves fit into near where the spokes overlap.
Then on the other side is another similar plastic washer, and a bolt with loc tite .
It held up great for about 10 miles now of hitting 20-25~ and some no load wheel up WOT's, is where I noticed a few bolts are getting loose. It was alittle difficult to put the loc tite on so that's why it's loose.
I don't see any dangers, it hasn't moved the spokes at all, You'd need to use a crap ton of force
No idea what type of sprocket mounting that is LOL
Peter16
42
Australia
are there any sprocket adaptors like the manic mechanic one which still utilise the standard 9 bolt pattern? (even if only 3 of the 9 bolt holes are used)
Ludwig II
5,071
783
UK
I posted elsewhere, but I'm going to be using dished sprocktes, cuts out the need for an adaptor to a disc brake hub.
