um... well I would if it weren't for two lil things, one - I do a
lot of distance at top speed and I'm concerned about running too lean a mix and two - Ima coward lol
I have it set to the second leanest setting as it is, but I just cut 1" of the internal baffle in the stock muffler and this
seemed to help - particularly in combination with opening up the airbox a bit. With that thought in mind, I think I'm gonna hold off until I get the tuned pipe kit and a less restrictive air filter, a K&N if I can find one I can make fit.
Joe - you mentioned that these motors 4-cycle less after they've been broke in... This makes me wonder about friction and drag, maybe even a heavy oil mix contributing to the problem... I think that when I finally use up this seemingly endless 5 gallons of fuel I'll try a high quality synthetic oil, @ the same 32/1 ratio I'm using now (it's finally past the break-in) - or would you suggest a different ratio? A hotter plug range? (NGK-B5HS) Am I barking up the wrong tree?
Thanks for your patience, this forum is great! Although there's a plethora of small engine techs around me (I live at a marina BTW), they all just look at my bike and scratch their heads lol They're so used to the uber-complicated, super-tuned Yamaha outboards and whatnot they have no idea about such a basic motor like my lil china-girl, without a computer diagnostic port they're a little lost heh
Well, to be fair they're not performance techs and with the motors they work on it's just "broken = replace" - there's little to none of the "fiddling" involved w/a engine like ours.
