new clutch or new motor
wheelbender6
4,059
221
TX
If your clutch works, but the pucks (they look like mini brakepads) are worn down, the repair is cheap and requires no unusual tools.
Beyond that, it's probably to better to get a new motor.
Maybe you can give us more details.
I thought I had a bad clutch, but after some disassembly, I found a trashed bearing on the shaft behind the sprocket was the problem and it was a cheap fix.
bandito
783
colorado
When a clutch replacement will equal a motor replacepent w/clutch some thing isnt right in my opinion......but your engines are so reasonable and the happy t gear box I can see your enthusiasm for it.
