#1 I've been having problems with my kit, Okay so my problem is clutch squeaking and drag ,I'm pretty sure it's my clutch because once I have my engine running and I pull the clutch in and it's idling (where the engine is on and running but I can pedal still) the noise goes away . (While I pedal and the engine is off ,there is no noise/squeak only when the engine is running and the clutch is out)But once I pedal and get up to speed and release the clutch it starts squeaking pretty bad like louder than the exhaust while I'm riding it. Also it drags, it's kinda hard to explain but basically while im riding , the drag I'm talking about feels like ,if I was to apply the bike brakes a little bit
#2 The shaking , I need to always be giving my bike alittle bit of throttle if not ,if I just leave it without giving It throttle it starts to go slower and slower till it's going about 1-2 mph then starts shaking real bad and eventually turns off. Also I know it's not my idler screw because once I hit my clutch in while it's shaking it will either just idle and shaking goes away or it will just turn off once I hit the clutch in.
I will make a video tommorow and I will post it
