Engine Burning?
jowens
128
Webster Fl
Is it possible that a Flying Horse engine could be burning up magnetos on a regular basis. I ask this question due to having no spark previously on this engine but corrected it by swapping the magneto out with one I knew for a fact worked. Today riding down the road the motor just stopped running and is not delivering a spark just like it did when I replaced the magneto before?
Thanks in advance for any help you may be able to lend me
rustycase
Gutter Rider
May 26, 2011
2,746
Left coast
I think the first question folks will ask is abt your kill switch...
What are you using?
Second question will be abt the status of that white wire...
Do you have it capped off nicely?
It is odd that two have gone bye-bye in succession...
I'd start with the above and take it from there.
Good luck
rc
jowens
128
Webster Fl
What are you using?
Good luck
rc
Thanks for the reply.......not using any kill switch....the first time I replaced the magneto I did not have the white wire protected when I switched the magneto I did cap the white wire and ensured that it would not short.....the engine only has about 200 miles on it and its acting just like it did when I replaced the magneto the first time
jowens
128
Webster Fl
Alright I finally got my replacement magneto in the mail yesterday and put it in.........low and behold it started right up.....Im still worried that the engine is going to kill the new mag tho.....while cruising the engine does what I used to think was 4 stroking, now Im starting to wonder if it is lack of consistant spark.....anyhow Im up and running again hopefully I will stay that way.
DaveC
969
Boise, ID
I know he just said he wasnt using a kill switch, but if he had been, wouldnt it be connected to the white wire?
You can but you shouldn't. The white wire is a 6 volt line ment to run a headlight. Shorting out the circuit through what is supposed to be power to the lights just isn't the right way. Your kill switch's two leads go to the wires from the CD, one killswitch wire to each CD wire. That way your shorting out the CD circuit.
If your not going to be using the lighting circuit then tape off the white wire :)
rohmell
1,531
6
New York
The soldering of the magneto's coil lead that goes to ground is often a cold solder joint. It is possible that this joint opened up due to vibration.
A simple resoldering of the lead might be all that is needed to repair those magnetos that are not working.
jowens
128
Webster Fl
The soldering of the magneto's coil lead that goes to ground is ofter a cold solder joint. It is possible that this joint opened up due to vibration.
Would it look broken because on both of the magnetos I have replaced the coil lead looks fine...?
jowens
128
Webster Fl
Also the engine once again sounds like it is going to have the magneto go out again.......while cruising the engine does what I used to think was 4 stroking, now Im starting to wonder if it is lack of consistant spark
rohmell
1,531
6
New York
The easiest way to check is with an ohmmeter between the blue or white wires and the magneto metal body. If no continuity, then you know that there is an open circuit for the ground.
jowens
128
Webster Fl
Thanks for the help rohmell, one last question if it proves to not have continuity but the solder looks fine how do I go about doing re-soldering it......in other words how do i prep it....getting rid of the crappy solder...heat it and melt it off?
rohmell
1,531
6
New York
Reheat the connection so that the solder melts, carefully lift up the lead and see if it is clean, it might have insulating varnish on it, clean with sandpaper or razor blade. Reheat the solder until it melts, adding fresh solder helps, insert lead into molten pool of solder and let cool. To overcome the thermal mass of the magneto, you have to use a large iron or gun, around 100W or so.
jowens
128
Webster Fl
I figured I would add a little to this thread as all of a sudden my engine is running far better than I have ever had any engine run for me......previously I was worried that my magneto was going to go bad again due to the engine having a hesitation in it......this has magicaly dissapeared and Im not gonna complain...this is truely a learning experience with this little china girl...and at times I sometimes wonder if its not luck on my side rather than my aquired knowledge from this fun little project Ive hooked myself on
.xx.
GearNut
5,104
11
San Diego, Kaliforgnia
A cold soldered joint can still show continuity when tested with a meter, but exhibit a very high resistance to electrical flow when the component is expected to operate.
jowens, unless the cold soldered connection was executed exceptionally bad by the factory worker it will appear to the naked eye to look nearly identical to a properly soldered connection.
jowens
128
Webster Fl
LOL!!!.....are you suggesting I fix it ESPECIALLY if it doesnt look broke.
I only say that because I already said it to myself seeing that both coil lead wires on the magneto look perfectly soldered....thats why I asked rohmell if it would not look broken but still be crappy in a previous reply on Thursday.
Thanks for the info GearNut
GearNut
5,104
11
Well if the mag does not work, what do you have to loose trying to fix it?
I all honesty though, I have worked with electronics for 31 years and repaired motorcycles for 29 years. I have seen (and made in my early years) plenty of poorly soldered connections that looked perfectly good.
The other connection that is known to fail is where the blue wire attaches to the lead coming out of the mag's windings.
nightcruiser
1,180
USA
Solder joints sometimes take a trained eye (and good eyes) to see the fault, sometimes cold solder joints can look perfectly good. Like someone else said, you already counted the magneto as dead, so why not poke at it and try to fix it? You have already been given good advise on technique, I might add that it seems prudent to pay extra attention to the lead that solders to the core of the magneto, that is where the black wire gets its connection and where the ground hits the motor.
I can't find my notes from when I had a magneto on the bench, but I think it measured something like 300 Ohm Black to Blue, and 30 ohm black to white. Not 100% sure on those numbers but I think that is in the ballpark, (black to white might have been even lower) I have heard enough about poor solder joints on magnetos to suggest this might be what you have going on here. If you do have a bad solder joint the resistance measurements would reflect higher numbers. But not necessarily, as things heat up and cool down these connections sometime make better or break cause metals expand/contract when they heat and cool. If you take your dead magneto and measure the resistance (at coil wires, not blue to black) and read something around 300 ohm then the magneto coil is probably OK and you just have bad solder. Also, I noticed that the wire used on these magneto's is total crap. I couldn't even get it to hold together after twisting. Sometimes crappy wire like this doesn't like to take solder, you might be better off getting some quality wire to replace the three wires on your magneto...
