It's a 66cc China Girl:
I have a problem with the engine either revving like crazy or stalling when the clutch lever is pulled. I took the carb apart, everything looks normal. For laughs I used a spare carb and tried that, exactly the same problem. With the carb off the bike but connected to the throttle cable, I can see the needle and sleeve moving up and down nice and smooth. Occasionally I can get a more reasonable idle rpm, but then the rpm's creep lower and lower until the engine stalls, or I blip the throttle and it goes up to 5000rpm and stay there. (I have a rpm gauge). The carb idle adjust screw is frustrating because I either get high rpm's or a stall, there is no happy medium. The engine runs fine when it's driving the rear wheel, it's just aggravating to pull up at an intersection, pull in the clutch lever, and either the engine rpm's go to maximum or 0. The clutch is not dragging, because with the clutch lever pulled in and the rear wheel off the ground, the wheel doesn't move. Any ideas?
FYI - the magneto coil has been replaced too with a spare, no improvement. I didn't try replacing the ignition block or throttle cable because I don't have a spare one of either of those to hand.
