You just reminded me of that long skinny bolt on Pontiac engines that went from the timing cover to the intake manifold. They would break if you stared too hard at it!When I did say old Ford F150 type water pumps There was always a couple of bolts that would be rusted quit a bit. I could never put them back in rusty per say as I would not get a proper torque reading from the bolt when putting it back in. So I would go to the wire wheel at the bench grinder and buff the threads clean.
Oops, should've written what was in my head....when it comes to building a Harley engine I use red loctite on the cylinder studs (after douching the threads with acetone and blowing them dry) and torque them. Then the cylinders and heads go on but won't I don't torque the head bolts (actually they're nuts) until the next day. The threads on the bolts (nuts) get a drop of oil.Guess it depends on the type brand locktite? Because I have some stuff here that if it was allowed to set over night my torque reading would be like those rusty threads? Is what I am trying to say.
The reason for doing it this way is because the studs get only 10lbs of torque into the case while the nuts get 32lbs. The thing to keep in mind is that fasteners don't hold things together because you have X pounds of twisting force but because of the STRETCH you induce when tightening them. This is CLAMPING force and is calculated by the materials involved along with the thermal cycling and forces that are expected in the application.
Must lay down now, brain overheating....need to use some brown loctite made by Jack Daniels.
