ok this is not technically a mb, but its one of my other toys, and i have seen these engines on bicycles before. it is a 49cc chinese piston port 2 stroke, they are usually red, anyways the engine was running perfect until it just died right out. i took it home, rebuilt the carb(diaphragm carb) and made sure its proper. still no luck, i put the carb and manifold from my engine bicycle onto it. i know the carb works, i fueled it up. held the primer down, and it still wont run, however get this. if i pour a little fuel into the carb it will start right up! i can rev it or it will idle fine, but it dies very shortly afterwords, even if i rev it up, its only running on the prime, but i know the carb works. i even tried another little diaphragm carb and its the same, so the problem isnt the carb, im stumped. any input would be graciously accepted
