Hi guys,
Got my clutch shaft disassembled from my HT, to adjust the inner spring for a lighter pull on the lever as I've read here somewhere.
While at it, I've noticed that the bearings have a bit of resistance, I'm not sure if it was from the grease covering the balls. I was thinking of replacing it again but this time I will not remove the rubber covering from the bearing side, keeping it sealed.
The question is should I remove the rubber covering or it's not a good idea in the first place? Or just keep the bearing sealed?
I'm very sorry if my English is a bit messed up.
Thank you in advance and I hope all is well in your area in this times.
Jeco pec.
Jeco pec.
