Chain idler question
Doopmaster
7
Orlando
Is it absolutely necessary to install the chain idler? I have my whole motor installed with chain but I forgot to put the chain idler on and the chain has 1/2-3/4 inch deflection. Thanks
buhz
37
clearwater fl.
a new chain will get longer so yes you need it old chain not so much.only other option is shims on motor mount. ride safe BOBdance1
Pilotgeek
403
Green Bay, WI
I don't use a chain tensioner/idler. Though I do have the alignment almost perfect between engine and wheel sprockets.
I only recommend using no tensioner/idler though if you have horizontal dropouts and a dérailleur to tension the pedal side.
