I had a PM sent to me..Yes I was very critical of the video clip and for a number of reasons. Please let me explain...
PM sent.....[/QUOTE]For your consideration, without explanation the above seems more insult than constructive criticism.[/QUOTE]
Sorry, I couldn't hardly stomach the first two minutes, let alone a second on the second clip. I wouldn't recommend those video's to anyone...well maybe for a general overview, and I mean BASIC GENERAL, but not installing the kit.
Right off the bat, as we all know that the heads are not true and can cause a gasket to blow out. This takes a few minutes to true up a head..NO COST, or very little for sandpaper. I would never recommend taking a engine out of the box and installing it especially drilling a hole in the frame..some get by with it, but not all. Engines are designed for the head to be torqued to specifications another reason for head gasket blow out. And the tools...really, Vice Grips, Needle nose pliers, both a Phillips and slot screwdrivers, 8mm and 10mm socket, ratchet, chain breaker tool, I guess you don't need a drill to mount the throttle, and drill a hole in the frame (which I don't recommend) and drill bits. As far s BASIC installing yes but I wouldn't recommend the clip as a way to visually explain it. I'm sure there are many other items that need to be covered, but for someone especially those that don't understand, or are not familiar with engines, they need to know. I know that I might go overboard on certain basic modifications that keep a engine running basically trouble free, but some really needs to be addressed, coming right out of the box. Look around the forum (as you know) and you can see all the posts about studs striped, thread holes stripped, engine mounts broken, and more. Any reason for that...you know what causes it.
As you can see he didn't put the bike together with only the tools he told you that you would need. That's like we go hunting and I give you a sling shot to kill birds with, that's all you need. But when I go I take a shotgun.
