That is a wholly uninformative remark, please just answer the question or dont. I would like to know as well, how can this be done at home and is it worth it?With regards to "Happy Time" engines, it means you are trying to polish a turd.
Actually it's quit the contrary a slightly rough surface flows the air better. Read this sticky and all will be thoroughly answered here. http://motorbicycling.com/f52/basics-port-polish-port-matching-16646.htmlThat is a wholly uninformative remark, please just answer the question or dont. I would like to know as well, how can this be done at home and is it worth it?
With regards to what it is, in automotive terms at lease polishing means forcing an abrasive putty through the intake manifold (or whatever you are trying to polish) to smooth out the surface of the metal inside to maximize airflow and prevent micro-currents of air that restrict overall flow.
per wikipedia, under cylinder head porting and myths
The reason that polished ports are not advantageous from a flow standpoint is that at the interface between the metal wall and the air, the air speed is ZERO (see boundary layer and laminar flow). This is due to the wetting action of the air and indeed all fluids. The first layer of molecules adheres to the wall and does not move significantly. The rest of the flow field must shear past which develops a velocity profile (or gradient) across the duct. In order for surface roughness to impact flow appreciably, the high spots must be high enough to protrude into the faster moving air toward the center. Only a very rough surface does this.
I imagine it would be similar to how rocks in a stream create a faster current.Actually it's quit the contrary a slightly rough surface flows the air better.
And why golf balls have dimples.I imagine it would be similar to how rocks in a stream create a faster current.
I understand what it is now, thanks for putting up that link.Actually it's quit the contrary a slightly rough surface flows the air better. Read this sticky and all will be thoroughly answered here. http://motorbicycling.com/f52/basics-port-polish-port-matching-16646.html
