This is going to be hard to describe but I'm going to try anyway. What LOOKS like a gap between the head gasket and the seating surface may not actually be. I thought I had the same issue so I took the acorns off, lifted the top of the heat sink off the motor so I could examine how it seats against the gasket. Turns out there is a circular raised area that meets up with the metal head gasket in such a way that it is will seal even though visually it looks like there is a slight gap between gasket and engine head, it is in fact sealed. Okay am I crazy? Can you check haoleboy and see if yours is like that?
I swapped out the acorns for some shouldered hex nuts but now I understand why the head doesn't *appear* to seat against the gasket once properly torqued to ~130 in/lbs.
