Yah, doesn't seem to me to be a natural stance for a bike unless OP is gonna run a tall rear and a small front...
Rear mount is most important... Application of power is trying to pull that engine through the seat post to get at the back wheel.
or, trying to pull the back wheel up to the engine!
Front mount is to stabilize, and, to hold the front of the motor down against the torque of the fire-breathing hp created in side the bowels of china girl...
You could take a half-round file to the mounts... Top of the rear, and bottom of the front, and change the angle of intersection with the frame tubes.
(I did so on my front, as many others do. I do NOT feel rubber mounting with an inner tube shim is a wise choice.)
...See how it looks with your selected front forks and wheels mounted up temporarily. You are pretty close and could most likely compensate for a little bit of angle by tweaking the float level.
Another option might be a short section of some sort of rubber tube in the intake tract. Some folks do it just to lessen vibration at the carb...
Good luck
rc
OR,
the dreaded single bolt T mount on the front...
