Bike being used is a 2012 GT avalanche Xl frame 26" tire. Got the bike off craigslist for 100$ could not pass up the deal considering the bike goes for 540$.. found a few still going for 350+.
engine kit is the black slant head from engines online shop.com has 30 day warrenty.
Parts order -upgraded 7mm copper wire & ngk boot,ngk plug ,TI-wrist pin/copper head gasket from juice moto, upgraded hardware & Loctite ,oil from local mx race shop.
Rear sprocket adapter from pistonbikes. or the HD hub kit from Dax.. need opinions on that .
Mods to do- clutch cable easy pull, clutch adjust
possible carb upgrade not sure which one , then expansion chamber most likely from a kx65.
Issues-is the oval frame but ive seen a avalanche 2.0 another member used and mentioned the SBP large HD frame mounts .. which is A U-bolt with a flat piece of steel bar with 2 holes drilled in it. I located a website that has (HD steel muffler clamps) which im sure I can find a clamp to fit my bike then rubber mallet the U bolt to form fit it shouldn't be to hard.
http://www.delcity.net/store/Saddle...t_1.r_IF1003?gclid=CJCowOLF5rwCFRQV7AodUB4Aeg
tell me if I have missed something
