Hey guys,
Ive just started my first build with a Huffy Mambo 26" beachcruiser and a 66cc 2 stroke kit. I bolted the rear drive cog on with the teeth pointing inwards toward the tyre and spokes so the chain would run closer to the wheel as per the instructions. Now I find that I dont have enough clearance between the drive chain and the side of the tyre. Is this pretty common with beach cruiser builds?
Im thinking about flipping the cog around so the teeth point away from the wheel so I get abit more clearance between the chain and tyre wall.
Problem two, after installing the rear cog, I find that the coaster brake arm is now interfering with the nine bolt heads as the wheel spins around. Again, is this pretty common? I will try giving the brake arm abit more of a kink so it will clear the bolt heads on the rear drive cog.
Any advice would be great, thanks.
