So I'm thinking I may rotate my HF79cc engine and install it with the cylinder vertical as many people are doing for a more b!tchin look. When I did a minor exterior teardown on my engine to see how I could fit it in my bike frame, I noticed that the carb is mounted to the engine using two pressed in 2.75" long studs.
Depending on orientation, the carb must be repositioned to sit relatively level in the frame. Are you guys using some sort of custom adapter/manifold to rotate the carb? I assume it must be machined. Seems like I have seen pics of peoples bikes with vertical engines and it looks like they are using radiator hose to attach the carb to the engine????
