Hello all,
I have been doing tons of research on this site while preparing for my build. I am a bit concerned about the one way bearing failures on the 80 tooth belt pulley.
I think I understand it correctly that because I have the 5/8 shaft HS 49cc engine, it comes with the 80 tooth, one way bearing setup.
Did the older tapered shaft use the 100 tooth fixed pulley with the inner chain pulley having a freewheel mechanism?
If this is correct, should I consider (or can I) convert it to the 100 tooth style?
Thank you
Thank you
