Heads Up on New HS 4 Stroke Clutches
fredgold52
156
Illinois
For no good reason in particular, I bought a new clutch, just the inside with shoes part, from Bicycle Engines .com. I had a bunch of questions which BE people answered and they sent my new clutch very quick. Those guys are good.
When I put the clutch on and ran the bike, I was surprised to see how quickly in engaged. Right off idle. I decided I needed the engine to be more in its power curve before the clutch kicked in. So I got some washers and took the clutch apart.
The springs were a surprise. Very much lighter than the ones in my original clutch. So I changed them over and now everything works fine.
This new clutch engages lots smoother than the older one did. The new one has a pattern on the shoes that looks like a tire tread. The shoe material seems a bit softer too.
If you are a lightweight, you may like the low rpm engagement. But if you are a 'widebody' like me, having some power built up before engagement is a good thing.
Bottom line? The new clutch is smoother than the older one, but you may want to change the springs out.
dance1
The_Aleman
2,653
I bought my new clutch from them recently and it's definitely better than what my 4G came with. My bike runs better than ever, kudos to B-E!
As far as engagement goes, these HS49s will lug under ~3800 RPM, and a higher engagement will be harder on the drivetrain. I find the new clutch perfect, myself.
Solution for you maybe, push-off from a start, pedal once or twice, then pull that throttle!
Fugi93
144
illinois
At what speed is it engaging now compared to the old clutch? Also, what speed does it disengage for coasting? I found that with a wet clutch that you can vary things a lot just by what fluids you use and how much in different combinations, which for me adds a lot of flavor to things. Maybe that will be a popular topic someday, but there is no need to go on about that.
The_Aleman
2,653
My July 2010 4G came with a clutch that was too large for the shaft and engaged <2000RPM. It was hard for me to keep the clutch shimmed straight, so it sometimes locked the drum, which would of course stall the engine at idle. OCscully gave me some 58lb springs for the clutch (he found 60 to be the best on our old-style clutches, stock was ~40) and that helped out a lot, but still engaged at idle when hot. However, my clutch was still oversize and would sometimes get cockeyed on the shaft. The HS has a goofy metric keyway and you pretty much need to hand file a .187 to fit, and do it right. I pretty much lived with it and it kinda unstuck itself after a few stop-and-gos. Made new keys as needed because that crap banged around.
Through January 2012 after passing the 4000 mile mark, the clutch locked really bad and my setup could not idle at a stop for weeks. One night the T-belt rotor detached from the clutch drum, like it did back in 10/2010. I had it welded back then, but over time the keys and the sloppy clutch had eaten up the whole weld! Also, the clutch shoes were not worn out, but the inner hole had wallowed out bigtime. Was starting to get some clutch grinding on the engine. Timely break.
I ordered a new clutch and drum, and what's offered now is definitely better than what my 4G came with. The new drum and rotor are put together like shown in cobrafreak's post, whereas the old was simply pressed in and maybe half-soldered. My new clutch engages smoothly towards lockup (~3K) with my light pedaling and allows easy idling, just slightly starts to engage when very hot at a stop, prolly due to the bushing crap I need to get rid of. My engine idles 1900-2100.
Fugi93
144
illinois
Do you happen to know what MM OD that clutch is? And does it fit the shaft without too much play? I don't know if they all the same or not, but the shaft on my 142f is slightly less than 15mm.
Fugi93
144
illinois
I got a reply from www.bicycle-engines.com/‎
about this.
"Our 5/8 Clutch O.D.= 82mm or 3.22835 inches
Our Clutch bell O.D.= 88mm or 3.46457 inches
Our Clutch bell I.D.= 84mm or 3.30709 inches "
For the few Hoot guys out there, this means we are in the money, honey! You may have to shim your shaft though because the older HS142F shaft for these gear boxes was slightly smaller than the newer motors that accept these clutches. I had to order a new motor anyways. Will update if any problems.
worksuxxx
135
Omaha
So are you saying the new 142f's with the attached "hoot" gearbox come with this new clutch? Or would you need to order it as a replacement?
