Hey everyone, Lots of good information and great projects on the forum!
Here's mine when I got it.
Here's a video once I cleaned it up a bit and pulled the gas motor.
https://picasaweb.google.com/lh/photo/MrgvfapmdriOEDipLVUVOd40RariheDeOtf3l5HavKs?feat=directlink
More videos and images are at the link below.
https://picasaweb.google.com/114640...authkey=Gv1sRgCKbEkZHS64GxsQE&feat=directlink
Rake and Trail
The initial images with the gas engine the trike has a positive trail which make is want to dive into a turn which make is want to flip over very easy and not corner very well. Currently I have flipped the forks backwards which gives me a funny look but allows about 1 inch of trail for a nice ride.
I have done some research on rake and trail and have discovered many ways to get into the range of negative trail for better handling. I'm going to change the headstock rake by adding 15 degrees to get more of a chopper look and get proper handling.
This will most likely mean I will need longer forktubes or shorter lowrider cranks.
I am not a very good welder but I do have a gas welding setup and I seem to bet better every weld.
Anyone have any good tips to share about gas welding? I have a donor bike I am going to use to practice on before I do much of anything to the trike.
The 2 stroke gas engine
It does not seem very powerful at all and perhaps even the centrifugal clutch is slipping more than it should. I will not be keeping it on this project for a couple of reasons.
No gas engines on our local Bike Paths period, no power at all but with electric I can still use it up hills as long as I am not causing a hazard.
I plan on taking my dog many places and she does not like engine noise and would not enjoy the ride.
So basically at this point no gas engine but I want Electric.
What Electrics to buy?
So this is why I am here. I have been looking around quite a lot and it seems like there is a ton of information available about motor specs, battery sizes, battery types, hub vs motor, etc...
What I don't see or just can't seem to be able to find is any good charts on the effects of Voltage, Wattage, unitWeight, AmpHours, and any way to correlate how it all works out on the road (distance & speed).
i.e. if I get a 36V-800W motor how does that compare to 24V-800W or 48V-800W?
I don't necessarily want to go fast, I'm thinking of maybe 20/25 mph top speed with a cruising speed of 15mph. I do plan on pedaling quite a bit but you all know better than I how much that works out once you have power available.
I think I want to have a front hub motor, that perhaps will be just enough to maintain a cruising speed on level ground for the longer hauls. and then a nice motor for the rear to get me up to speed and to help on the hills.
Any ideas? am I on the right path? should I get the rear motor 1st and then maybe the front later? would the front motor have enough traction if I got a powerful motor and used it to get up to speed?
Brakes
This ride currently has no brakes and I'm having a hard time deciding on what to do.
The front OCC chopper style forks will not hold a caliper for disc brakes. No crossbar for clamping brakes.
The rear end axle is securely mounted to the right rear tire and the left rear tire is freewheeling.
My donor mountain bike has cantilevered brakes but I would need to weld the studs onto my forks, this seems scary as welding to the forks will weaken them correct?
Can a front hub motor be set up to do regen braking and would that be enough to stop me?
Any ideas are greatly appreciated!!
My Overall plans
Install front hub motor and batteries. (hub motor should allow future disc brake mounts)
Install some sort of braking.
Install lightweight wood Chariot style rear end (see images above)
Ride the heck out of it!!
Phase 2 may be part of Phase 1, not sure yet..
Change Headstock rake.
New fork tubes or entire fork assembly
Front Disc brakes on new forks
2nd motor for the rear
My budget is under $1000 total and I ended up paying $500 for the trike (not counting the $75 in gas to go get it). so already unless I get a slamming deal on motor and batteries I am over budget already- lol
Rake and Trail
Brakes
My Overall plans
