Hi zazbeam,
EZM's Q-Matic drive requires a 56 or larger rear sprocket when used with the 49 CC 4-stroke HS 142 or the Honda GXH50 motor. Several of the 4-stroke kits use the 56 tooth rear spocket. Several lighter riders [myself included] have used 48 tooth rear sprockets on the 4-stroke motors for testing top end limits, however the wind & hills can slow it down quickly.
There are a lot of choices in drive systems, some are really bad, some you can live with, and some that work well. As a Vendor it isn't wise to point out additional information, I just think a little research on this site might lead you down a safe path.
The 49 CC 4-stroke motor is a great choice, both Honda & H S. All H S motors are not the same, some are wider, the crankshaft length varies [important to consider because of drive choices], and crankshaft O.D. sizes vary.
Have fun,
